Could you tell us what all you have tried? Also why still on 380.70??I tried it all, I can't seem to be able to open port 51413 for Transmission on a Asus RT-N66U running Asuswrt-Merlin 380.70.
Any help would be greatly appreciated.
Because that is the last version for that router model.Could you tell us what all you have tried? Also why still on 380.70??
Indeed I am! I run a VPN client in AsusWRT-Merlin firmware, constantly on and the have binded Transmission to an internal ip which is routed through the VPN-tunnel.From your other post here: https://www.snbforums.com/threads/a...dress-for-asus-aicloud-ftp-application.57904/
It sounds like you’re routing your traffic through a VPN client, so I think it complicates matters more. I don’t run a VPN client, but if this is still your setup, it might help others chime in.
All the ports are open when using an OpenVPN client on 380.70. How are you determining that port 51413 is not open?Indeed I am! I run a VPN client in AsusWRT-Merlin firmware, constantly on and the have binded Transmission to an internal ip which is routed through the VPN-tunnel.
Hi, thank you for taking the time to address this issue of mine.All the ports are open when using an OpenVPN client on 380.70. How are you determining that port 51413 is not open?
Bear in mind that you would have to be connecting to a VPN server that allows P2P connections. If you want to forward a particular port like 51413 you would have to ask them to set it up on their servers for which they usually charge an additional fee.
This is expected behaviour. The firewall-start script won't help you because the port would have to be forwarded by your VPN provider.I tried https://canyouseeme.org/ and also Transmission lists port 51413 as being closed. I tried opening the port by running a firewall-start script but to no avail.
My VPN provider allows P2P-connections (I use Anonine).
How can I enable port forwarding?
You can enable port forwarding in user panel. External port - is one is accessible from internet, internal port - the one that you open on your computer.
What should I do to enable port forwarding on my computer?
Nothing, after enabling port forwarding in client area and connecting to vpn, the port will be already forwarded to your computer.
Why can't I change public port?
Public port is assigned automatically to any user due to security and reliability reasons. It will be assigned to user and cannot be changed. This specific port will be valid on any server and will be forwarded automatically after re-connection/changing a server.
Why is that?You need to be checking port 11167.
I tried https://canyouseeme.org/ and also Transmission lists port 51413 as being closed. I tried opening the port by running a firewall-start script but to no avail. My VPN provider allows P2P-connections (I use Anonine).
Public port -> Outside looking in (or outside/public facing)Why is that?
I understand. I checked the port through the website and its still closed. I guess I will need to make a configuration on my router as well?Public port -> Outside looking in (or outside/public facing)
Local Port -> Inside looking out (inside network)
Would it be done from GUI or through Putty, Im guessing Putty since Transmission seems to run on a lower level.Yes
You've already stated that you've made non-standard modifications to Transmission to get it to work through the VPN. We don't know what those modifications are or the implications of those changes.Would it be done from GUI or through Putty, Im guessing Putty since Transmission seems to run on a lower level.
I have to agree with @ColinTaylor. We are just throwing darts in the dark. How did you make changes previously regarding the port? GUI or putty?
I have removed Entware and Transmission, I reformatted the JFFS partition.You've already stated that you've made non-standard modifications to Transmission to get it to work through the VPN. We don't know what those modifications are or the implications of those changes.
You need to open 11167 not 51413 on the router. 11167 is the public facing port.......I have removed Entware and Transmission, I reformatted the JFFS partition.
I still cannot open up the port, right now I have set my VPN provider, Anonine, to open port 51413 and I have also configured port forwarding on the router as below:
Thanks, but it still doesn't work.You need to open 11167 not 51413 on the router. 11167 is the public facing port.......
See this...it may help.
https://www.asus.com/support/FAQ/1037906
Welcome To SNBForums
