Can't Ping Ethernet from Wireless Device
nadhif.o
I uses Asus AX56U with Merlin. I had Canon Imagerunner as a printer connect to router with LAN and it use static IP Address. I can ping it when my device connect to LAN so can use it to print. But when my device connect via wireless, it can't ping my Canon Imagerunner so I can't use it to. Whats should I do?
Welcome to the forums @nadhif.o.
Are you connecting to Guest Network 1?
When you say you can't ping, what error did you get?
Can your wireless device ping the router?
Can your wireless device ping other wired devices?
Can other wired devices ping your wireless device?
