MdRS
I have an ASUS RT-AC88U
I have got a lot of problems since Merlin version 380.64_2 like hangs and some inside systems not working as UPNP Media (DNLA)
And with the last one the Router hangs a lot only working with trasnmission. Then I decided to reinstall all the Entware to make it clean, and see if it helps a little. My main problem now is that I can't rearm JFFS to make work ENTWARE, and that's because when it's formatting and mounting it founds one bad block in the nand.
I don't know if it's a way to make it work manually or if could be a new firmware with the capacity to work with bad blocks. I really apreciate information, because i have investigated some and have seen that there isn't any upodates about this since 2012.
