Can't run multiple guest networks simultaneously
fr33z0n3r
Is this a bug? I'm trying to run multiple guest networks. Why are there 3 slots in the GUI, if I can't even run 2 of them?
Device: AC68U
Jack Yaz
Part of the Furniture
Define "can't run" - what happens when you enable them, or do you mean the GUI prevents you from turning them on?
fr33z0n3r
Version 384.19
This new SSID is a second 2.4Ghz Guest SSID - I have a 2.4Ghz and a 5Ghz Main SSID as well.
When I try to enable this 2nd Guest Network, it acts like it does it but it never actually appears in a wifi list on my phone. Yes, I know how to manage wifi. No its not hidden. No I didn't overlook it.
When I press F5 on the Guest Network page, the 2nd Guest SSID info disappears and shows the Enable button, while the first guest network I have is still displayed (and working fine).
RMerlin
Asuswrt-Merlin dev
Works for me. I can get two Guest Network running at once on my RT-AX88U, both are visible.
fr33z0n3r
I"m wondering if I'm hitting a limitation for my model? The 3 active SSIDs being a max? I reset the config for this version, and I only use it for basic firewall and these SSIDs. Would be strange if this was a hardware problem.
RMerlin
Asuswrt-Merlin dev
Lack of available NVRAM would be my first guess.
fr33z0n3r
Right now it says 62MB used of 256MB. Anyone have any other ideas?
Checking the log, I notice this, which sounds like a bug.
<15>1 2021-01-18T15:22:06-05:00 RT-AC68U-2AD8-A2BD388-C syslog - - - syslog: Error unlocking 5: 9 Bad file descriptor
<15>1 2021-01-18T15:22:06-05:00 RT-AC68U-2AD8-A2BD388-C syslog - - - syslog: Error unlocking 0: 9 Bad file descriptor
Here is the full debug log when trying to enable this feature. It starts at ~ 15:30:29 and finishes the progress "bar" at ~ 15:30:39
Jan 18 15:30:29 rc_service: httpds 261:notify_rc restart_wireless;restart_qos;restart_firewall;
Jan 18 15:30:29 syslog: Error unlocking 5: 9 Bad file descriptor
Jan 18 15:30:29 syslog: Error unlocking 0: 9 Bad file descriptor
Jan 18 15:30:30 kernel: device eth1 left promiscuous mode
Jan 18 15:30:30 kernel: br0: port 2(eth1) entering forwarding state
Jan 18 15:30:30 kernel: device eth2 left promiscuous mode
Jan 18 15:30:30 kernel: br0: port 3(eth2) entering forwarding state
Jan 18 15:30:30 kernel: device wl0.1 left promiscuous mode
Jan 18 15:30:30 kernel: br0: port 4(wl0.1) entering forwarding state
Jan 18 15:30:33 kernel: device eth1 entered promiscuous mode
Jan 18 15:30:33 kernel: br0: topology change detected, propagating
Jan 18 15:30:33 kernel: br0: port 2(eth1) entering forwarding state
Jan 18 15:30:33 kernel: device eth2 entered promiscuous mode
Jan 18 15:30:33 kernel: br0: port 3(eth2) entering forwarding state
Jan 18 15:30:33 kernel: device wl0.1 entered promiscuous mode
Jan 18 15:30:33 kernel: br0: port 4(wl0.1) entering forwarding state
Jan 18 15:30:33 kernel: device wl0.2 entered promiscuous mode
Jan 18 15:30:33 kernel: br0: port 5(wl0.2) entering forwarding state
Jan 18 15:30:36 acsd: selected channel spec: 0x1003 (3)
Jan 18 15:30:36 acsd: Adjusted channel spec: 0x1003 (3)
Jan 18 15:30:36 acsd: selected DFS-exit channel spec: 0x1003 (3)
Jan 18 15:30:36 acsd: acs_set_chspec: 0x1003 (3) for reason APCS_INIT
Jan 18 15:30:38 acsd: selected channel spec: 0xe22a (44/80)
Jan 18 15:30:38 acsd: Adjusted channel spec: 0xe22a (44/80)
Jan 18 15:30:38 acsd: selected DFS-exit channel spec: 0xe22a (44/80)
Jan 18 15:30:38 acsd: acs_set_chspec: 0xe22a (44/80) for reason APCS_INIT
Jan 18 15:30:39 syslog: WLCEVENTD wlceventd_proc_event(466): eth1: Deauth_ind 8E:2C:BB:96:8C:84, status: 0, reason: Class 3 frame received from nonassociated station (7)
Jan 18 15:30:40 syslog: Error unlocking 5: 9 Bad file descriptor
Jan 18 15:30:40 syslog: Error unlocking 0: 9 Bad file descriptor
Jan 18 15:30:40 syslog: WLCEVENTD wlceventd_proc_event(500): eth1: Auth 8E:2C:BB:96:8C:84, status: Successful (0)
Jan 18 15:30:40 syslog: WLCEVENTD wlceventd_proc_event(529): eth1: Assoc 8E:2C:BB:96:8C:84, status: Successful (0)
Jan 18 15:30:41 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Jan 18 15:30:41 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Jan 18 15:30:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Jan 18 15:30:41 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Jan 18 15:30:41 kernel: HTB: quantum of class 30010 is small. Consider r2q change.
Jan 18 15:30:41 kernel: HTB: quantum of class 20010 is small. Consider r2q change.
Jan 18 15:30:41 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Jan 18 15:30:42 syslog: WLCEVENTD wlceventd_proc_event(500): wl0.1: Auth C8:3A:6B:E7:3B:1A, status: Successful (0)
Jan 18 15:30:42 syslog: WLCEVENTD wlceventd_proc_event(529): wl0.1: Assoc C8:3A:6B:E7:3B:1A, status: Successful (0)
RMerlin
Asuswrt-Merlin dev
That`s unlikely, the RT-AC68U has a total of 64 KB of nvram.
fr33z0n3r
ah, was reading from the main page in the UI.
But I think I found my issue. I set the new network to way too short a duration. I think it was stopping the network right after starting it. I didn't realize what that value would do. I figured it would boot a user after being connected for a specific timeframe, but it shuts down the SSID after that long instead.
