Presuming the 75-foot run is solid core, 802.3at should propagate no problem. If it's stranded core, it should work, but you'll have higher line loss (thus, why solid core is always used for longer runs with PoE). The shorter pieces of patch are almost assuredly stranded core, but should carry 802.3at/af no problem at such minimal length.
I personally don't use Monoprice. It isn't necessarily bad, per say, but I'd rather use legit TAA/BAA commercial-class brands like Belden, Berk-Tek, Mohawk, Superior, Panduit (I could go on...). Look for stuff like that at local commercial distributors or surplus warehouses. In the US, you can find it online for fairly cheap. Berk-Tek LANMark Cat6 can be found cheap in several places. Vertical Cable is another brand that's good as well (made in the USA, too).
Trip, any recs on where I can buy some legit RJ45 inline coupler keystone jacks (just for ease of use)?
The ones I have gotten at monoprice have the circuit board in them I think, they constantly fail on me.
Circuit board?
sorry, disclaimer, I may have no idea what I am talking about, so bare with me. I was reading some reviews on the RJ45 inline coupler keystone jacks on monoprice and amazon, they were mentioning some circuit board in there that would go bad (which has happened to me on more than one occasion).
Have been googling all morning, trying to find some legit ones other than monoprice.
Thread starter | Title | Forum | Replies | Date |
A | Testing Cat6 in the new home network | Switches, NICs and cabling | 14 | |
T | PoE does not work over self-built CAT5E cable | Switches, NICs and cabling | 6 | |
A | Dumb vs Managed PoE switch | Switches, NICs and cabling | 4 |
Welcome To SNBForums
