A
a.k.a.
Guest
Hello everyone,
I am looking for your advice on the best value in an external enclosure setup. This is hard to get good advice on. Even if you just have a site to point me to, I'll take that as a useful bit of advice.
The purpose is to provide greater than 1TB backup space for a laptop that can control this enclosure either via an ExpressCard eSATA port (30-70MB/s transfer rate), or via a Gigabit-Ethernet port for NAS. I'm not willing to buy a setup that caps my storage at 1TB.
I have looked at the NAS transfer rate charts, and I'm not exactly impressed with the off-the-shelf designs in the lower end of the price range (15MB/s for the 321 or ReadyNAS), so I'm considering DAS through the SATA line.
How barebones am I willing to go?
1. I am looking for the entire diskless framework to come out well under $200, but anything below $300, if it adds considerable flexibility and performance, is something I'll consider seriously.
2. While it defeats the purpose of a secure backup, it is important enough to me to get costs down for the moment that I am happy to choose a diskless NAS that is capable of running on just one 1+TB HDD, with additional drives added later on.
3. I would prefer RAID1, I think, but that can be either on the software or hardware side. It's my assumption that JBOD-only enclosures mean I will need to back everything up two times, rather than once. I have access to Vista, Server 2008 and SBS 2008 as far as software controllers -- not WHS, since it's not part of the MS TechNet testbed offerings. I haven't looked at or priced the SteelVine solution, but it's very intriguing!
4. Another barebones scenario: If you can get good performance out of just a "backplate" enclosure and nothing more, I'm happy to put up with the noise. The obvious problem is that it needs a power source and potentially a controller. Or, if there's an extremely cheap way to do desktop NAS via SATA-SATA or Gig-E ports, I'm happy to consider it.
Now what's my ideal?
1. SAS or Uxx SCSI, with some sort of a SATA out port, and a software controller solution that I can run from the laptop.
2. 3-5 swappable (or best, hot-swappable) bays, with cheap adapters for all the spare 2.5" drives I've accumulated. Plus, a way to run that setup as a 2-bay RAID1 + 1-3 JBOD setup.
3. A fast NAS (over 30MB/s) at as low a price as your basic 2-bay RAID1 setup.
THANKS A MILLION!
a.k.a.
THANKS A MILLION!
a.k.a.
