Change channel?
Slickone
Should I change the channel of my router (top of the list)? The two Roku's ("hidden network") are mine too.
I can barely read that on my display... but it appears to suggest using 2.4 CH11 at 20 MHz and n-only, if you have no bg clients.
I wonder if those are the earlier WiFi Direct Rokus that will follow your WLAN to whatever you set it for (annoying). My Roku Ultra WiFi Direct stays put on 5.0 CH 36.
OE
Only if the current one is giving issues. Change for change itself isn't required.
psychopomp1 Best 6ghz wifi channel? General Wi-Fi Discussion 14
