Change Control Channel in AiMesh
Grigione
Hello,I wish to know if it's possible,in main router, to change control channel after an initial AiMesh configuration and if AiMesh Node working ok after change.Thank you in advance.
You will need to turn off smart connect and then should be able to change channel.
