change openvpn log level
WillUK2010
Hey Merlin,
how do i change the verb level from 3 to 5?
i added it to custom config, but dont think that made a difference.
regards,
Will
I just checked the code, and it seems it's currently hardcoded to 3. I suspect that adding it to the custom script doesn't override it.
I'll look into making it configurable in a future update.
Ok mate,
maybe you can help... im trying to get OpenVPN working... (followed the tomato guide to the letter)
Open VPN in UDP mode, lets me connect, but i cant ping hosts on my lan.
Changing to TCP, it just wont establish a connection, Tunnelblick on my mac, just constantly cycles a connect/disconnect sequence.
(i have xx my ip's)
Sep 21 16:39:07 openvpn[1621]: MULTI: multi_create_instance called
Sep 21 16:39:07 openvpn[1621]: Re-using SSL/TLS context
Sep 21 16:39:07 openvpn[1621]: LZO compression initialized
Sep 21 16:39:07 openvpn[1621]: Control Channel MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sep 21 16:39:07 openvpn[1621]: Data Channel MTU parms [ L:1544 D:1450 EF:44 EB:135 ET:0 EL:0 AF:3/1 ]
Sep 21 16:39:07 openvpn[1621]: TCP connection established with xx.xx.xx.xx:46872
Sep 21 16:39:07 openvpn[1621]: TCPv4_SERVER link local: [undef]
Sep 21 16:39:07 openvpn[1621]: TCPv4_SERVER link remote: 31.105.231.214:46872
Sep 21 16:39:10 openvpn[1621]: xx.xx.xx.xx:46872 TLS: Initial packet from xx.xx.xx.xx:46872, sid=4478eb92 8970c800
Sep 21 16:39:11 openvpn[1621]: xx.xx.xx.xx:46872 Connection reset, restarting [-1]
Sep 21 16:39:11 openvpn[1621]: xx.xx.xx.xx:46872 SIGUSR1[soft,connection-reset] received, client-instance restarting
Sep 21 16:39:11 openvpn[1621]: TCP/UDP: Closing socket
No idea, sorry. I don't deal with Macs. Must be something specific to its client configuration.
