Change "workgroup" in an AiMesh router ...
Leguar
Have an RT-AX88U (primary) bound to an RT-AC68U node (AiMesh).
My LAN's workgroup name is "GW43", but my node shows up as
"WORKGROUP".
How can I change the node (RT-AC68U) to be in the same workgroup ??
Thanks ...
SSH into the node and issue the following command.
nvram get st_samba_workgroup
If that returns "WORKGROUP" then change it as follows:
nvram set st_samba_workgroup="GW43"
nvram commit
Then reboot the node to see if it works.
nvram commit
Thank you Colin,
Will try it over the weekend. If it doesnt work, I will disconnet the node,
and do the change with the RT-AC68U, and the connect it again as node
for the RT-AX88U.
Glad to hear it worked.
There's no documentation for nvram particularly because it's just a way of manipulating variables in flash memory. So like any other programming environment the variable names and their meaning could be anything.
If you want to have a look at all the currently defined variables enter the following command:
nvram show
  • Like
Reactions: a5m
