Changes in SSH in 384.13_10
RMerlin
Asuswrt-Merlin dev
Yes, obsolete algos like 3DES were disabled, for security reasons.
GoNzCiD
Thnaks @RMerlin, it maybe explains the reason for the `[Errno 104] Connection reset by peer` error I have using the python module aioasuswrt.
Is there any choice to temporary re-enable this to ckeck if it's the error and/or get time to update the library?
RMerlin
Asuswrt-Merlin dev
No, it's a compile-time setting.
test011
Note that Home Assistant to asuswrt connectivity is also broken with RT-AC87 384.13.10
GoNzCiD
For new versions I hope it will be solved. There is a new aioasuswrt release published that resolve this issue, if you want you can modify the version of this dependency to .7 and it will work.
