Channel width question
Gar
Does the channel I choose effect the bandwidth available to that channel? For example, if I choose 165 am I limited to less than 80?
Yeah 165 is 20Mhz only.
Thanks. An android app shows a reduced bandwidth, but I wasn't sure it was accurate because the graphic doesn't center on it, or 161 for that matter. 161 appears to be 40mhz then.
No problem.
Here is an image that kind of explains the channels.
