CHKWAN - Address http://proof.ovh.net/ down
joe scian
Hi Martineau
Address http://proof.ovh.net/files/md5sum.txt seems to be down or at best variable and intermitent and hence chkWAN is rebooting the router and/or restarting WAN. . Any idea why the site seems to be down? Also http://proof.ovh.net/files/100Mb.dat . This was happening around 1-3.30pm AUS E time. ANyone else running ChkWAN.sh having similar problems ?
ChkWAN.sh): 30292 ***ERROR WGET 'http://proof.ovh.net/files/md5sum.txt' transfer FAILED RC=28
Dec 10 15:30:48 RT-AC5300-0680 (ChkWAN.sh): 30292 v1.13 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 10 15:30:48 RT-AC5300-0680 (ChkWAN.sh): 30292 Starting cURL 'small' data transfer.....(Expect 500Byte download = <1 second)
Dec 10 15:30:48 RT-AC5300-0680 (ChkWAN.sh): 30292 NOTE: Transfer rate must be faster than 100 Bytes/sec
`ChkWAN.sh): 30292 ***ERROR WGET 'http://proof.ovh.net/files/md5sum.txt' transfer FAILED RC=28
Dec 10 15:34:22 RT-AC5300-0680 (ChkWAN.sh): 30292 v1.13 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 10 15:34:22 RT-AC5300-0680 (ChkWAN.sh): 30292 Starting cURL 'small' data transfer.....(Expect 500Byte download = <1 second)
Dec 10 15:34:22 RT-AC5300-0680 (ChkWAN.sh): 30292 NOTE: Transfer rate must be faster than 100 Bytes/sec
Hi Martineau
Seems to be working for me...
Yep
started working OK again from 17:30 hrs Australian Eastern standard time.
ovh.net appears still down, so I have decided to host the 'forcesmall' 500B file on Github, and replaced the 12MB file with a 10MB file hosted by cachefly.net.
ChkWAN v1.17 available on Github
Thank you very much Martineau
