Cisco RV320 Routing Mode Not Working
coxhaus
Part of the Furniture
I have a Cisco RV320 router. When I add a couple of static routes and turn on routing mode instead of gateway mode I lose internet access. If I click gateway mode internet comes back for the default LAN.
Does anybody have routing mode working? It could be I am not using DHCP and I have changed the default IP from 192.168.1.1 to 192.168.0.1. My AT&T web pages uses 192.168.1.254 for my U-verse statics on my line so I have skipped the 192.168.1.0 network.
If someone has it working I may try to change my IP addresses.
I guess this was operator error.
I did not realize the wizard added an ACL for only the default network. So I added an ACL to allow networks in the static routes range and with the router in gateway mode it seems to be working in gateway mode.
I also thought when you added static routes you needed to be in routing mode not gateway mode.
So check your ACLs when using this router.
