Cisco SLM2008 or Netgear GS108T?
simpleminds
Simple question; Cisco SLM2008 or Netgear GS108T? Are there any important differences?
Can they do anything about arp poisoning and/or dns spoofing? Does the QoS support setting diffrent priorities on different ports rather than just limiting the speed to a fixed value? Can flow control be disabled in both of them? Because FC should be disabled in a small 100/1000 mixed network... right? Actually, when should it be enabled?
Price is almost the same, GS108T is only marginally more expensive so the price is not important. Thanks very much! :)
I don't think either will do anything about arp or DNS.
The NETGEAR supports port rate limiting and port priority mapping. The Cisco supports only port priority.
Both support flow control enable/disable on a per-port basis. See When Flow Control is not a Good Thing.
