This is perfect! Is it just enough to run this command under SSH or do I need a restart after that?Thank you, Colin - believe it or not, I had searched all kinds of "clear arp cache" options, but got nowhere near what you did - thank you for this - it was just what I needed!
The effect is immediate. Although I don't really see why there's a need to do this.This is perfect! Is it just enough to run this command under SSH or do I need a restart after that?
While trying to solve my AIMesh issue, I removed one of my existing nodes and re-add it, just to make sure there is no issue with my method. While I fixed the mesh issue, I noticed that the node I removed and re-add, is now acting properly as an Mesh node, but also appears as an "ASUS" device on that node. When I disable this "ASUS" device, all network devices registered via that node, lose internet. I thought clearing teh arp table would help. I even cleared the NVRAM of the main router (but restored from backup), to no avail. Any other ideas?The effect is immediate. Although I don't really see why there's a need to do this.
I'm sorry to be bumping this topic with my question. If I want to remove only one entry from the arp table that has PERM status is this below command correct?Tried Google?
ip neigh flush all
ip neigh del 172.16.0.55
You need to add the interface that is associated with the entry, i.e.I'm sorry to be bumping this topic with my question. If I want to remove only one entry from the arp table that has PERM status is this below command correct?
Code:ip neigh del 172.16.0.55
I have the stock firmware and I know that I could do a reboot of the router then the arp table would be cleared. I know maybe it's a stupid question but I'm just learning.
ip neigh del 172.16.0.55 dev br0
Thread starter | Title | Forum | Replies | Date |
M | nvram staticlist will not clear | Asuswrt-Merlin | 25 | |
U | multiple entries using ‘arp-scan’ but not reflected in ‘arp’ command | Asuswrt-Merlin | 3 | |
Where is asus blocking ARP for guests? | Asuswrt-Merlin | 1 | ||
Solved Dnsmasq cache statistics? | Asuswrt-Merlin | 6 |
Welcome To SNBForums
