Robert Wyman
I have a ax88u and a ac88u as a node connect hardwired.
when I scan my net with any sniffer scanner i have 61 clients and have confirmed this to be true but the router in aimesh node connected only reporting 56 clients but if i remove aimesh and put the ac88u into Access Point(AP) mode all clients report and appear ....I am using Manually Assigned IP around the DHCP i have aprox 30 manual set ips I have tried factory resets many time have the most current firmware installed. Anyone have any thoughts since system stability seems to be poor and throughput is also slower with aimesh running.
