ergoProxy
I need to isolate my old devices (1 tablet, 1 kindle) from the other devices (pc, mac, smartphone) inside my home network without using the wireless guest network. They should only be able to connect to the internet. What is the most effective way?
I tried with Firewall - Network Services Filter but I am not sure if it works.
example:
Source IP: "1.2.3.4", port range: empty, destination ip "1.2.3.4/24", port range: empty, protocol:TCP
Source IP: "1.2.3.4", port range: empty, destination ip "1.2.3.4/24", port range: empty, protocol:UDP
Thank you
P.S. RT-N66U Merlin 380.66_4
example:
Thank you
