clients list do not update correctly 386.1 AX88U
Unetwork
hello,
Since the installation of verison 386.1 my clients do not update correctly.
It's been 30 minutes since I turned off the 3rd device (PC) and it's still in the list...
Is there a solution ?
on the other hand in AImesh there are only 2 PCs left. There must be a bug ?
thank you for your help, long life to merlin !
Unetwork
Doesn't anyone have this problem?
I just did a factory reset again and same problem, the client list doesn't update on the home page when a device is turned off.
I didn't have this problem in 384.19.
FTC
Yes, the appearance of phantom devices that are disconnected in the network map is a known problem reported multiple times during the 386 cycle. This seems to happen also in stock 386 firmwares.
Unetwork
thank you for the information I didn't know. I hope the problem will be solved in the next version.
@RMerlin if you see this post, a correction would be greatly appreciated.
long life to the project and thank you for your work !
octopus
hello,
Seems working for me, shows up when add a new LAN-device (windows-10) but there is problem as "View List" not refresh itself.
Have to update side to get it disappear.
Marigno
hello,
I have two RT AC88U both updated to 386. I had to downgrade both to 384.19. Everything in the UI was slow on the main router, the Aimesh connection unstable and the clients didn't update. After downgrading the main to the 384, leaving the 386 on the mesh node, it seemed to work well. But I downgraded also the mesh node.
RMerlin
Asuswrt-Merlin dev
Networkmap is closed source.
Unetwork
@Marigno ; @octopus ; @RMerlin
thank you for your response. Indeed, I have just flashed version 384.19 again and I have no problem with Networkmap, when a client connects, it appears in the list and when it disconnects, it disappears from the list quickly.
I just flashed version 386.1 again and Networkmap doesn't work anymore, clients are still connected, even after 6 hours of PC shutdown.
Edit : the update to version 386.1.2 + factory reset + configuration manualy + format JFFS partition not solve this problem.
thank you for your work and your reactivity.
