Closing OpenVPN client kill WAN connection
Steve Blencowe
Hi, I have an ASUS AC86U running the latest non beta Aususwrt-Merlin.
I set up an OpenVPN connection (using PureVPN .ovpn config files) and set up the split tunnelling feature to have VPN on one specific device.
This works fine.
However whenever I close the VPN connection on the router I loose connection to the WAN - which requires a router reboot to solve.
Has anyone else experienced this?
This works fine.
Do you have the KILL-switch ENABLED?
Not sure! At work now so will check tonight. Thanks
You can copy and paste the following command into a SSH command window:
ip rule;for I in 1 2 3 4 5; do echo -e "ovpnc$I table 11$I";ip route show table 11$I;done
which should prove if the 'prohibit' (aka KILL-switch) keyword is ENABLED for any of the VPN clients.
I have the kill switch option off - "Block routed clients if tunnel goes down" set to No. Tried again. Set up to route Nvidia Shield via VPN. Worked fine. Stopped VPN and WAN connection severed until I reboot router.
If I remove the split tunnelling the VPN works for everything going via the router and when I turn it off all is OK.
Odd.
I have run this and cannot see any mention of 'prohibit'.
Found a workaround. After closing the VPN - and left with no WAN I click on 'Internet Status' and turn off the internet connection and back on again. This regains my WAN connection. Not great but at least I don't need to reboot the router each time.
When it happens again, open an SSH terminal and enter this. Note the underscore.
service restart_wan
If that works, there are scripts here than can check for the wan up / down and issue that command via script and / or cron job.
service restart_wan
Yes running that script in SSH brought the WAN back. Thanks. Where are the scripts you mention?
