Cloudflare over DOT showing Singapore on DNS tests
Luboknok
Using the DNS Privacy feature of Merlin my ac86u set to Cloudflare servers 1.1.1.1 and 1.0.0.1.
IPleaks reports both a Singapore IP and DNS address, I am in the USA. Otherwise the connection seems to work. Is this expected?
edit: tested on https://www.dnsleaktest.com/ and it reports the same IP but reports USA.
skeal
Part of the Furniture
Cloudflare has been having problems in the USA.
SomeWhereOverTheRainBow
my "USA" servers are reporting properly.
are you sure your browser hasn't hijacked your DNS traffic?
Luboknok
It turns out it's the VPNs DNS showing Singapore, even when DNS Privacy is activated with Cloudflare. I thought DNS Privacy would override pushed DNS. If not, what's the point?
Swistheater
you can override VPN dns by nat rules.
iptables -t nat -D PREROUTING -i tun_example -p udp ! --source 192.168.1.1 ! --destination 192.168.1.1 --dport 53 -j DNAT --to 192.168.1.1 2>/dev/null
iptables -t nat -D PREROUTING -i tun_example -p tcp ! --source 192.168.1.1 ! --destination 192.168.1.1 --dport 53 -j DNAT --to 192.168.1.1 2>/dev/null
iptables -t nat -A PREROUTING -i tun_example -p udp ! --source 192.168.1.1 ! --destination 192.168.1.1 --dport 53 -j DNAT --to 192.168.1.1
iptables -t nat -A PREROUTING -i tun_example -p tcp ! --source 192.168.1.1 ! --destination 192.168.1.1 --dport 53 -j DNAT --to 192.168.1.1
if you know which tun interface your vpn is using. you would replace tun_example with that.
or if you want to go by IP range of your vpn interface you can do it by that as well instead of doing it by interface.
there are alot of fun things you can do to control flow of traffic with nat rules.
