Command to check vpn client status ?
federom
Hello everyone,
I am using a script that establishes a vpn tunnel using service start_vpnclient1 and i use stop_vpnclient1 in order to close it..
Is there any command to check the vpnclient1 status?
Thanks in advance !
Fede
Try
nvram get vpn_client1_state
a value of '0' should mean it's off. There are a couple of other states for 'on' (a non-zero value), but I think it's not always correct other than indicating it's not 'off' :)
Try
Thanks John !! It works really well !!
Thanks again!
