sma
Hi there - is there a command I can run on the router while connected over SSH that provides a list of active devices on the network in the same way that the "Client Status" screen shows on the home page? I'd like to integrate this into a monitoring script to determine when network devices connect or disconnect from the network. The script will be run every 30 seconds or so. I've tried finding the relevant page in the source code to try figure this out myself but I couldn't work it out.
Thanks!
Thanks!
