Comparative Info of Different RT-AC3200 Hardware Versions?
Is this just for informational purposes? Or do you have another question or issue you're trying to solve?
I am planning to get a AC3200 and thus would like to know if there are particular hardware versions that would be worth aiming for.
None that I know of.
But, that model is EOL, for a long time now. Not worth buying today.
I am using 3rd-party FW's on my routers/bridges, so OEM EOL is generally not a significant factor.
Then it shouldn't matter which revision (if any) is used.
