Seth Harman
I normally run my AC86U with a single VPN connection running which is utilized by a limited number of clients on my network, all other clients go out unencrypted. I decided to try setting up a second VPN as a catch-all to encrypt all the other clients not locked to the first VPN. This did not go well, performance on both was pretty sub-par (original VPN went from ~70Mbps to ~11Mbps, second VPN was also ~11Mbps). As soon as I turned off the second VPN performance of the original VPN went back to ~70Mbps. Should I give up hope that the AC86U can handle two concurrent VPNs without performance of both being poor?
