I think this is the right forum for this -- apologies if not...
I have an Arris TG1672G cable modem (with integrated router) from Time Warner/Spectrum. They are charging me $5/month for "wifi" and I decided I would get a separate router to put behind the cable modem and discontinue the Spectrum Wifi surcharge. The router I purchased is a Synology RT2600AC (based on feedback I have seen in FNB forums). I am trying to figure out how to optimally configure this combination.
1) I want to use the Synology router to control the network and not simply use it as an Access Point. Is that the recommended route?
2) Assuming that it makes sense to let the Synology Router control the show for the home network, I would want to disable functionality on the cable modem and enable it on the Synology router, namely, things like DHCP, NAT, firewall, Bridging, etc. Which services should I turn off on the cable modem and enable on the Synology Router? I will turn off the wifi capabilities on the modem.
3) What ip addresses and address ranges do I assign to both the cable modem and the Synology router, assuming the Synology router is controlling the network DHCP and is controlling the range of network ip addresses? Separately, but related, I already have 1 access point (an old asus router set up for AP use) on the existing network with a static, assigned ip address in the range of the DHCP server provides today -- should that be moved out of the active range? Currently, the ip address range is 192.168.0.1 (for the cable modem) and 192.168.02 to .255 serving as the active assignable ip address range.
4) Ideally I want to enable services on the Synology router like VPN server, to allow me to remotely connect into my network and use it as a vpn service for when I am away. Does that change anything above?
Thanks for the advice and help!
