Configuring IPv6 neighbor
strumf666
Hello and apologies if I made an error in topic name; I am not sure about the correct term.
Anyway, my ISP can only provide static IPV6 with/through the use of a neighbor, for which, when I was still using pfsense, I was told to use a "npd -s" command in a startup script. With asuswrt&merlin is it possible to configure this in GUI?
I tried through ssh, but "ndp" seems to be missing in asuswrt&merlin? Or am I doing something wrong? I am not too familiar with linux/bsd/... stuff :-/
Thanks in advance for any help.
Apparently your ISP doesn't support Prefix Delegation, so you need to run a Neighbor Discovery Proxy (NDP is one, there are others). I can't log into my ASUS router right now to check, but I haven't run across that function in the Merlin software that I can recall, but I've never needed it. Openwrt supports it.
