Confused about firmware install
beerglass007
Hi all
Having fixed the slow performance issues with my new AX86U [ it was the drivers on my PC ] i'm now happy with the new AX86U as a replacement to my AC68U
But its currently on Asus firmware and i'm missing some options like DNS over TLS
Reading the forums looks like its either a beta2 or beta3 release can be installed on the AX86U. But i'm confused as to the install since its been years since i've installed Merlin from nothing
On the main wiki https://github.com/RMerl/asuswrt-merlin.ng/wiki/Installation its just another simple firmware upgrade
But loads of talk on here about reset, reboots, 3 times over and formats and loads of other stuff....is this really required and why ?
No, that stuff is not normally required - unless you're experiencing strange behaviour that you cannot resolve (in which case a simple factory reset is usually all that's necessary). In normal circumstances you would just install Merlin's firmware through the GUI just like any other.
Do read the release notes for the particular release that you plan to install because occasionally there's some specific change that might require special action. And of course a beta release is just that - beta. Use it at you own risk and there may be bugs or special procedures required to install/configure it.
Read not for the 'how', but the 'why'. :)
New M&M 2020
Fully Reset Router and Network
Troubleshooting 101 for Asus/RMerlin Routers 2020 https://www.snbforums.com/threads/troubleshooting-101-asus-rmerlin-routers-2020.65438/post-605773
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
M&M Config https://www.snbforums.com/threads/n...l-and-manual-configuration.27115/#post-205573
Sanitize Network https://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
Save NVRAM Settings https://www.snbforums.com/threads/asus-dsl-88u-transfer-settings-question.42274/#post-359390
Control Channel Set up https://www.snbforums.com/threads/a...details-in-the-description.55582/#post-472051
Control Channel Setup 2 https://www.snbforums.com/threads/very-slow-on-2-4ghz.26942/#post-205456
RT-AC3100 Report https://www.snbforums.com/threads/s...-go-with-the-rt-ac1900p-v3.34748/#post-281391
Are you safe with VPN https://www.snbforums.com/threads/to-vpn-or-not-to-vpn.55600/page-2#post-472951
WPS NVRAM Erase https://www.snbforums.com/threads/b...eta-is-now-available.55520/page-9#post-473141
MU-MIMO Setting https://www.snbforums.com/threads/asus-rt-ax88u-experiences-discussion.49427/page-14#post-473643
Nuclear Reset https://www.snbforums.com/threads/major-issues-w-rt-ac86u.56342/page-4#post-495710
RT-AX88U Upgrade https://www.snbforums.com/threads/b...ta-is-now-available.60037/page-31#post-531024
Why a new SSID? https://www.snbforums.com/threads/i...-ax88u-rt-ac86u-node.60551/page-2#post-532915
Rebooting Ways https://www.snbforums.com/threads/rebootin-router-with-usb.61513/#post-545685
Unbound Report: https://www.snbforums.com/threads/u...-caching-dns-server.58967/page-53#post-547399
