Confused about Mac router and streaming speeds
fbx
I have the 24" iMac 2.66GHz with 4 G ram. Currently using Motorola SBG900 (Docsis 2) cable modem & router to stream Comcast through house (another PC, iPhones, LG Blu Ray player/digital video streamer).
Recently acquired a Netgear Rangemax 3700 which is supposed to be the fastest current wireless router. Here are my questions:
1) Can I just use the Motorola SBG900 as modem ONLY and run the ethernet out of it to the Netgear router (thus bypassing the router built into the SBG900). Will this accelerate the streaming of video to other receivers?
2) Would I be better off with a Motorola 6120 Docsis 3 Cable modem feeding the Netgear router (even though my Comcast cable feed is Docsis 2, not 3)?
3) Since my Comcast account is rated 10 Mbps max (though it sometimes goes up to 15 or so late at night) and I believe the existing Motorola SBG900 is rated at 54 Mbps, is the limiting factor the speed of my Comcast connection and all else doesn't matter? That is, is it impossible to speed up my streaming or download speed without a faster connection to the Internet?
4) What kinds of connections are there that are faster than Comcast cable connections?
Basically, I don't want to waste money or time if I'm already at the maximum throughput available given my connection. If I can get marginal speed increases by adding new modem and router, that's fine. I'll do that.
Thanks for your help.
PS: I owned and returned the Airport Extreme Base Station. It did not increase the speed of my connection or streaming, but then it tested very poorly here -- about half the speed of the Netgear Rangemax.
