Shutterman
I’m wanting to add an AP (or router configured as such) to an existing wired network in my home. The AP is for a new laptop that has an Intel 5300 adapter installed. No other wireless devices (yet).
The AP will connect into an unmanaged (i.e., cheap) existing 4 port gigabit switch. The switch connects back to an older gigabit wired router. Two computers on the network are also gigabit capable and wired directly to the router. All the above can handle jumbo frames.
This will be my first foray into the world of wireless computing, so the reviews and articles on SmallNetBuilder have been an invaluable resource.
One such review that caught my eye was on the D-Link AirPremier N Dual Band PoE Access Point (DAP-2553).
Two features that I found attractive about the unit are: 1) it has a gigabit LAN port, and, 2) it “can be powered by power wart or 802.3af PoE”. This last feature would make installation a ton more convenient, and would also provide me a great deal of flexibility in placement.
I was all set to pull out the plastic and place an order, when I noticed this comment at the end of Tim's review from a user who reviewed it:
“Two setbacks, first is that the Ethernet port is gigabyte, but when running POE max is 100 megabit (not DLINK fualt as most POE devices are this way). Second is that it will only run either 2.4 or 5ghz at one time”
I don’t care about the second so-called setback, but I was surprised by the first.
Is this correct…would this unit’s gigabit port only run at 100 megabit speeds if I supplied power via PoE? Is this user correct in that most PoE devices, particularly AP/routers, work this way? If so, what do I need to do to keep my gigabit and jumbo frame capabilities in tact? Do I need a PoE switch?
Any advice would be appreciated.
