I think the current router class system is simple enough, i.e. AC1900, N300, etc.
by also advertising what class your wireless client uses.
All that's needed on the box is a link (QR code) to an explainer article from a trusted industry source.
More seriously, smartphone manufacturers are the worst when it comes to Wi-Fi specs for their products.
Yes I had to check Asus website to get a better understanding and I'm not retarded, maybe tier 1 monkeyFrom another thread currently running...
"I'm searching for the best priced RT-AC88u which is the 3100, confusing because theres an AC 3200."
Bigger numbers aren't necessarily better numbers...
Non taken. We even found out there's two version of the 3100/rt88 one with 4more wan ports lolNo, you are not a tier 1 monkey - but it's a good case-study why current Vendor WiFi ratings are terribly wrong...
Apologies for quoting you out of context...
six
The WiFi classing system isn't perfect and refers to only one aspect of a WiFi router's value proposition. Also not perfect or a direct indication of router performance is # of processor cores and clock rate or RAM/Flash capacity.
That's why testing and reviews are done and there is no substitute for informed consumers.
Wi-Fi is a technology that's a victim of its own success. In the long term, Wi-Fi has to evolve to operate more like cellular, where the network is in charge, not the device and the user decision tree moves to features that are more understandable to the average consumer.
Welcome To SNBForums
