Connection Dropped
Donga120
I keep getting dropped connection on my Asus AC86U running 386_2 and now 386_3. Attahced is some logs if it helps, even the WAN cuts out as well as WiFi networks (both 2.4 and 5.0). Not sure what logs I need to post, but this was the last lot when it last went: https://pastebin.com/uhpZALE3
ColinTaylor
Part of the Furniture
Unfortunately there's nothing useful in that log file as it doesn't cover the time period that the problem occurred. It appears to only show a 10 minute period after the router had rebooted.
ColinTaylor
If the "dropped connection" happened at 13:00 in your log file that's because your router crashed and rebooted itself. The reason for the crash is unclear other than there was a memory corruption that caused a kernel panic.
Your log file is full of pktrunner ucast errors which might be related to the problem. I suggest that you start by removing your add-on scripts (Diversion, ntpMerlin and anything else) and seeing if that stops the error messages.
mcmxmk19
Can you elaborate on your “connection dropped?” I have been experiencing connection issues recently as well. My connection drops, all LEDs stay on, it’s for a moment or two. It’s at the router level, impacting all devices. My devices will indicate there’s no connection, then reconnect. It happens for maybe 2 times a day, for 2-3 minutes.
I am not running any scripts, I am running Quad9 as my DNS. My initial theory is that a incorrect DNS setup is the cause.
Donga120
Sounds similar. I have just initialized the router and setup as new. I only have Ethernet connections on, and so far after 1 hour, I have 0 errors or warnings on the log. As soon as I add a wireless device, it spits the dummy out and throws errors. Unfortunately haven't had enough time to test the connection drops yet but will update. I will also check the DNS theory, I was using Cloudfare 1.1.1.2 and 1.0.0.2 IIRC....
Donga120
Had been fine for 3 days, however it has now rebooted twice in the past 30 minutes... How on earth do you diagnose, reset to factory and add bit by bit?
Donga120
UPDATE: Left the router in the M&M state. Been perfect for 3 days, not a single issue, with Wi-Fi connections too. Will reformat the USB in a PC and add AMTM, then leave it for another 3 days and see how it goes. Will report back.
Donga120
It gave way again. I nuked the router again, setup M&M and within 15 minutes, 6 Apple devices and Ring started throwing the errors up, WAN and LAN light went off, the internet light went red before all going white again after 2 minutes or so.
Aug 24 20:52:38 wlceventd: wlceventd_proc_event(527): eth6: Auth AA:01:81:17:9E:DD, status: Successful (0), rssi:0
Aug 24 20:52:38 wlceventd: wlceventd_proc_event(556): eth6: Assoc AA:01:81:17:9E:DD, status: Successful (0), rssi:0
Aug 24 20:52:39 kernel: ERR: bdmf_attrelem_add_as_buf#4250: ucast: status:Entry already exists. attribute:flow index:4294967295
Aug 24 20:52:39 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_activate,1971: Cannot rdpa_ucast_flow_add^[[0m
Aug 24 20:52:39 kernel: ^[[0;33;41mBLOG ERROR blog_request :blog_key corruption when adding flow net_p=ffffffc016993dc8 dir=0 old_key=0x2000236c new_key=0x20002394
Aug 24 20:52:39 kernel: ^[[0m
Aug 24 20:52:42 dnsmasq-dhcp[3106]: DHCPDISCOVER(br0) aa:01:81:17:9e:dd
Aug 24 20:52:42 dnsmasq-dhcp[3106]: DHCPOFFER(br0) 192.168.1.153 aa:01:81:17:9e:dd
Aug 24 20:52:43 dnsmasq-dhcp[3106]: DHCPREQUEST(br0) 192.168.1.153 aa:01:81:17:9e:dd
Aug 24 20:52:43 dnsmasq-dhcp[3106]: DHCPACK(br0) 192.168.1.153 aa:01:81:17:9e:dd
Aug 24 20:52:46 kernel: ERR: bdmf_attrelem_add_as_buf#4250: ucast: status:Entry already exists. attribute:flow index:4294967295
Aug 24 20:52:46 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_activate,1971: Cannot rdpa_ucast_flow_add^[[0m
Aug 24 20:53:59 kernel: ERR: bdmf_attrelem_add_as_buf#4250: ucast: status:Entry already exists. attribute:flow index:4294967295
Aug 24 20:53:59 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_activate,1971: Cannot rdpa_ucast_flow_add^[[0m
Aug 24 20:53:59 kernel: ^[[0;33;41mBLOG ERROR blog_request :blog_key corruption when adding flow net_p=ffffffc0153d62e8 dir=0 old_key=0x20002866 new_key=0x200028b8
Aug 24 20:53:59 kernel: ^[[0m
Aug 24 20:54:01 kernel: ERR: bdmf_attrelem_add_as_buf#4250: ucast: status:Entry already exists. attribute:flow index:4294967295
Aug 24 20:54:01 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_activate,1971: Cannot rdpa_ucast_flow_add^[[0m
Aug 24 20:54:59 kernel: ^[[0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=ffffffc016993dc8
Aug 24 20:54:59 kernel: ^[[0m
Aug 24 20:55:17 kernel: ^[[0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=ffffffc016823a28
Aug 24 20:55:17 kernel: ^[[0m
Aug 24 20:56:29 kernel: ERR: bdmf_attrelem_add_as_buf#4250: ucast: status:Entry already exists. attribute:flow index:4294967295
Aug 24 20:56:29 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_activate,1971: Cannot rdpa_ucast_flow_add^[[0m
Aug 24 20:56:29 kernel: ^[[0;33;41mBLOG ERROR blog_request :blog_key corruption when adding flow net_p=ffffffc016993a28 dir=0 old_key=0x20002c02 new_key=0x20002c04
Aug 24 20:56:29 kernel: ^[[0m
Aug 24 20:56:38 kernel: ERR: bdmf_attrelem_add_as_buf#4250: ucast: status:Entry already exists. attribute:flow index:4294967295
Aug 24 20:56:38 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_activate,1971: Cannot rdpa_ucast_flow_add^[[0m
Not sure if these are the cause of the router rebooting itself, but I may just throw it in the bin and buy an AX86U....
Donga120
UPDATE: This has been traced back to Ring (doorbell, chime and security light). Very strange so I have temporarily disconnected them for now whilst I do some more digging.
Donga120
Was fine for around 10 days, added Ring about 5 days after it was stable, now it has crashed 3 times within 6 hours. Coincidentally, i have used airplay to an AV receiver and wonder if this may of caused the issue. Crash log is below:
ColinTaylor
There is no crash information in that log file. It just shows the normal boot up information (and the pktrunner entries).
Donga120
How do I find a crash log? Using Scribe it says:
Log file will display here. If you are seeing this message,it means the log file cannot be loaded.
Please check your USB to check the /opt/var/log directory exists.
I have FTP into the router but I re-installed Scribe beforehand, so I have this, however I am unable to open or copy log files so I can't view them due to permissions?
Donga120
I spoke to Asus who said it sounded like a hardware defect and I should go to the retailer I got it off, which was......Amazon. I went on the live chat and within 4 minutes was offered a full refund or replacement item, I went for the full refund option and I ordered a new AX-86U instead. Perfect service.
Sadly can't provide any details on what is/was wrong with the router but given it does it on factory settings after a full reset makes me think it is 100% hardware related.
