HarryMuscle
I'm trying to run an additional custom DNS server on a second IP address on port 53. However, it turns out that DNSMasq is configured with bind-dynamic which means it automatically binds to any new IP addresses added to the br0 (and other) interface. That means I can't start a second DNS server on a second IP address cause DNSMasq is already using port 53 on it. The opposite of bind-dynamic would be to configure DNSMasq with bind-interfaces so that it only binds to addresses existing on the interfaces when it starts up. However, I'm not sure if this is a safe thing to change or if DNSMasq is configured with bind-dynamic on purpose so that it continues to function under certain circumstances were IP addresses change. What would be the best approach to run a second DNS server on a second IP address on port 53 on the router?
Thanks,
Harry
Thanks,
Harry
