Geofram
I have two AC3100's running the latest Merlin (380.66_4).
The first is in the office, with the modem, serving an 5GHz network optimized for throughput and a hidden 2.4GHz network optimized for compatibility.
I want the second downstairs, repeating the 5GHz network for better coverage and serving an isolated 2.4GHz "guest" network with some filtering, but I also want to keep the 802.3ad bond between the network and the server's two Intel NIC's.
This is what I have working now:
This is what I'd like to have:
Having the extra LAN3 on the second router available is a nice-to-have - the priorities are:
1) Maintaining the 802.3ad LACP between the server and the network (either directly to the main AC3100 router or through the second AC3100 access point.
2) Having the second AC3100 act as a wired Access Point for the 5GHz network from the main router.
4) Not buying any more hardware (running more cable is not an option).
3) Enabling LACP between the two routers and then again between the second router and the server.
Any thoughts or suggestions would be so appreciated - I'm just about ready to give up and have the second AC3100 act as a wireless repeater instead (not ideal).
