CPU @ 100% with USB flash drive attached
Nexus
Just bought a new 32GB Kingston USB flash drive today and I noticed when I plugged it into my RT-N66U with the latest 1071 stock firmware that the CPU gauge of the router is locked @ 100%. This behavior occurs when the drive is formatted FAT32 or EXT2. Is this normal behavior? I've never owned a router with USB ports, so not sure if this is typical? Any suggestions/solutions would be appreciated.
I decided to restore the router to factory settings and then re-flashed the firmware. This appears to have solved it.
