1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Cpu temperature
Discussion in 'Asuswrt-Merlin' started by EventPhotoMan, Aug 9, 2018.
  1. EventPhotoMan
    EventPhotoMan Senior Member
    Mar 29, 2018
    325
    I’m always sitting at 92 degrees.
    Concerned I am.
    I do have almost all options turned on like QOS
    Any suggestions? RT-AC86U
  2. skeal
    skeal Part of the Furniture
    Apr 30, 2016
    2,613
    /etc
    Buy a laptop cooler or hot glue a small case fan to it. Really helps. If you search Amazon for ac68u cooler you will see the rig I have!
  3. Twiglets
    Twiglets Regular Contributor
    Aug 15, 2014
    169
    I got one of these:
    ELUTENG USB Fan 120mm Computer Fans USB Powered 54.56CFM 1500RPM PC Fan with Metal Grill Guard 5V/0.32A USB Case Fan for Laptop/TV Box/AV cabint/PS4/xBox 12cm https://www.amazon.co.uk/gp/product/B06XD9JBMB/
    [​IMG]
    Works very well, used plastic ties to hold it on ..... so no damage to router !!!
    In hot badly ventilated room temps for 56u router went from 82C to 57C !!!
    [BTW the router was running with no problems at the high temps for over 1 year BUT thought it was about time to cool things down when the 'Heatwave' happened, here in the UK. :) ]
    P.S. Set fan to blow air into router NOT suck air out !!!
  4. st3v3n
    st3v3n Senior Member
    Feb 24, 2016
    481
    Central US
    EventPhotoMan, For a long while we've used a silent 6" AC fan, 6 inches to a foot on either side of any router we've had, to push the air flow over, around/through the router. We're usually running at a steady 42.43 degrees, up to 50 on a really hot day, with, 2 concurrent OpenVPN tunnels running. Before using this fan, the router was much hotter. We can easily clean both side of the fan blades each month when we clean all of the gear. and can re-position the fan when needed without having to disassemble the router/fan, without any vibration or magnetic/radio frequency issues induced, as has happened when some lean toward using cheap cheap fans. Cheers.
    skeal likes this.
  5. EventPhotoMan
    Mar 29, 2018
    325
    Thank you. all
  6. EventPhotoMan
    Mar 29, 2018
    325
    Makaveli likes this.
  7. thelonelycoder
    thelonelycoder Part of the Furniture
    Jan 23, 2014
    5,048
    Switzerland
    HuskyHerder, SMS786 and Grisu like this.
  8. skeal
    Apr 30, 2016
    2,613
    /etc
    Makaveli and EventPhotoMan like this.
  9. EventPhotoMan
    Mar 29, 2018
    325
  10. thelonelycoder
    Jan 23, 2014
    5,048
    Switzerland
    Grisu likes this.
  11. OKLY
    OKLY Occasional Visitor
    Sep 19, 2014
    30
    My room temperature is usually around 30c and my AC86U's CPU temperature will hover around 76-78c.
  12. EventPhotoMan
    Mar 29, 2018
    325
    My room temperature is 21 degrees celcius.
  13. EventPhotoMan
    Mar 29, 2018
    325
  14. EventPhotoMan
    Mar 29, 2018
    325
    I added a fan today... by www.artic.ac called Breeze Mobile (mobile USB fan)
    I’m watching my cpu temperature drop from 92 degrees Celsius to 58 degrees.
  15. EventPhotoMan
    Mar 29, 2018
    325
    PS it’s super quiet for 11$ Canadian.
  16. EventPhotoMan
    Mar 29, 2018
    325
  17. skeal
    Apr 30, 2016
    2,613
    /etc
    If you check the small amount of power these things used you wouldn't be worried. If someone has a unassisted drive connected also then maybe you may have problems. But the one I showed does not have to be plugged into the router it just shows it that way as a convenience.
    thelonelycoder likes this.
  18. st3v3n
    Feb 24, 2016
    481
    Central US
    Good photos to add to the trove. Re Skeal's post, it's always a hoot to see that amz link pop up again. Judging by the lack of buyers for that unit, one would think twice, but there's always a way to part the uninitiated from their bucks when they don't know. That was merely a playful reference to 'unsophisticated' buyers/users, so no flames, please:) Most here don't fit that category and aren't as thin skinned and can take small jests in good humor.
    I reckon if the power draw isn't as much as the combined current used by a couple of docked 2.5 or 3 inch drives, or a USB flash drive and something on the order of a My Passport 3.0 USB drive, you shouldn't risk overloading the PSU. With any of the inexpensive stuff, the electrical specs are questionable testing prior to plugging it into your precious Asus router is advisable. The sub-$10 AC fan plugged into the wall has made sense. Currently running 2 OpnVPN concurrent tunnels, only 6 devices per temps on the the photo. Cheers all.
  19. EventPhotoMan
    Mar 29, 2018
    325
    Just another note....
    The importance of placing your router as the manufacturer says.
    I had 7dbi antennas on my ty-AC86U router on a shelf , the shelf is high in my office, and the router with the extra length antennas hit the ceiling. So I laid the router down horizontally and bent the antennas to go vertically.
    Now that the shorter antennas are back on ( moved the antennas to another access point) the router it vertical.
    With no fan...
    The routers cpu temperature was 92-93, and in the vertical position it dropped to 82.
    Just saying...
    With the fan, in down to 55 degrees
    No issues with power either and it’s the second device drawing power too.
  20. snakebite3
    snakebite3 Senior Member
    Sep 16, 2014
    267
    I'm using a thermal take 120mm.
    https://www.amazon.com/dp/B002OJN250/?tag=snbforums-20
    It gets the job done. The problem is fan uses sleeve bearings. I don't it's durable. I wanted high quality fluid bearing fan. Noctua recently make 5V USB fans. I'm not sure how to mount one.
