CPU usage
MakeItEasy
Hi guys,
There is almost no traffic but i never seen as much CPU since I have the router (the two CPU were always very low, +- 2/3% usage) so what is going on ?
Note I activated Ai Protected from 3 days but that seemed to change nothing for the CPU, at least in the beginning.
bbunge
Hi guys,
View attachment 27185View attachment 27187
My guess is you have a USB drive attached. Likely the media server doing a sync or Samba is reading the drive.
And, you should upgrade to the new firmware.
MakeItEasy
No, I don't have anything connected through USB.
Besides you remind me to disable USB. Still haven't found where this option is hidden in the UI.
ATLga
Hi guys,
Looks normal for trend micro turned on. Typically 20% bump over what it may have been prior to activating it.
bitsbytes
Hi guys,
when was the last time you did a factory reset? this happens to me after a couple of dirty updates and it goes away with a factory reset.
MakeItEasy
Seems like to a lot more than +20% !
I have the router since one month and I only do one factory reset/firmware upgrade.
MakeItEasy
The three ones.
Nothing in the logs.
The client list (although I know it is not very reliable) shows me devices that are disconnected.
I think I will do a reboot (18 days on).
OzarkEdge
Part of the Furniture
It's not AiProtection\Network Protection.
Did you reset after the firmware upgrade?
OE
MakeItEasy
After a reboot and more than 30 minutes, still back to normal (between 0 and ~5 % on each core).
Strange...
