Create Dynamic Custom Hosts File
bozolino
my geo-unblock dns provider publishes a .hosts file (via a static url) that gets regular updates. i would like to reflect those updates on my router. how can i create a daily cronjob to
1. download the .hosts file from my provider
2. replace the contents of /jffs/configs/dnsmasq.conf.add with the download
3. restart the router or the relevant (sub)system to update its hosts file
many thanks in advance!
What format is the hosts file from your provider? Standard ip host_name?
I'd use a separate file to avoid having to completely restart dnsmasq. Then one time add the line
addn-hosts=/jffs/configs/new-host-name
to /jffs/configs/dnsmasq.conf.add
Then since the dnsmasq hosts files aren't dynamic, you need to issue
killall -SIGHUP dnsmasq
to cause the host file to be re-read after you download it.
