Creating settings file from command line
medo
Is there a way to get the same file output from the command line as the one that is usually available from web interface at the Administration->Settings->Save?
I am trying to script a backup for routers config and I would really prefer to get it in CFG format instead dealing with raw NVRAM commands.
Any reason not to use John's User NVRAM Save/Restore Utility (R21)?
There is no need invent the wheel again and again... :rolleyes:
With kind regards
Joe :cool:
