mgiunktode
I'd like to use cryptsetup in voxel firmware... but I get this error:
root@RBR50:/tmp/mnt/sda1# cryptsetup luksOpen cryptodisk.dat encVolume
Enter passphrase for cryptodisk.dat:
Attaching loopback device failed (loop device with autoclear flag is required).
It might be related to the absence of moduel loop:
root@RBR50:/tmp/mnt/sda1# modprobe loop
modprobe: module 'loop' not found
Is it possible to solve this problem? Is there another solution for having an encrypted filesystem on the router?
Thanks,
Thanks,
