@dave14305
I managed to generate a CSR with that link you posted. Did take a little tweaking, but will post what I did below.
Firstly, I created a file in the
tmp folder on the router named
altnames.cnf. This file was then populated with the below which had the details of the certificate I needed.
mydomain.com is just an example domain, use your own, along with your own regional/org details.
[req]
distinguished_name = req_distinguished_name
req_extensions = v3_req
prompt = no
[req_distinguished_name]
C = GB
ST = Essex
L = MyHomeTown
O = Private
OU = Private
CN = home.mydomain.com
[v3_req]
keyUsage = keyEncipherment, dataEncipherment
extendedKeyUsage = serverAuth
subjectAltName = @alt_names
[alt_names]
DNS.1 = home.mydomain.com
DNS.2 = mydomain.com
I than ran the following command while in that same folder as above (note the filename at end of the command):
openssl req -new -newkey rsa:2048 -nodes -keyout home.mydomain.com.key -out home.mydomain.com.csr -config altnames.cnf
This then generated the CSR and private key in the
tmp folder. I could then use the home.mydomain.com.csr to generate a certificate at your SSL provider (mine being
https://cheapsslsecurity.co.uk) by just copying the text directly out of the CSR file. After validating the domain by adding a cname to my domain, the certificate was available for download.
Upon uploading the SSL certificate, I could upload to the router. You will need to upload the private key file, namely the
home.mydomain.com.key file. And then you upload the certificate from the provider, and Bob's your uncle!
