muffintastic
Current Issues In 384.4_2
1. Setting The Lease Time (Seconds) To The Max In LAN DHCP Option (GUI) It Will Revert To 2 Hours and not 31 days.
Log Output:
httpd: nvram_check fail: nvram dhcp_lease over length (7 > 6)
Fix:
You To Need Edit The dnsmasq.conf file within WinSCP and change line that says:
dhcp-range=lan,10.0.0.x,10.0.0.x,255.255.255.0,2678400s
Then Run in Putty/Kitty:
killall dnsmasq && dnsmasq
Then It Has Been Applied.
2. The Same Error Applies (Different Ouput) (Manual Media Server Path (Max Limit : 10 When Adding Folders From Your USB Device(s) With Filenames Such As "3DMovies" or "TVShows" Max Character Limit Of 5 I Assume, As I Only Have 3 Folders With That Limit.
3. Editing The WAN Section Within The GUI, From Changing DNS, Disabling UPNP Will Cause An Error With The Output ""nat: apply nat rules (/tmp/nat_rules_eth0_eth0) error!" The Issue And Fix And Replies Are Noted Here: https://www.snbforums.com/threads/no-step-closer-to-a-fix.45754/
Not Sure If There Are Any Other Issues To Report @RMerlin But I Hope These Will Get Fixed At Some Point Or Taken A Look At In The Next Release Or Future Releases.
Log Output:
Fix:
