Custom DDNS Issue
Tanner Harman
Hi, I am trying to create a custom DDNS script that will report the External IP address but I seem to be running into problems. Here is the Script I've put below.
#!/bin/sh
USER="Username"
PASS="Password"
HOST="www.safedns.com"
# Should be no need to modify anything beyond this point
IP=$(wget -O - -q https://www.safedns.com/nic/update)
logger "Retrieved External IP: $IP"
border:none windowtext 1.0pt;mso-border-alt:none windowtext 0in;padding:0in">RESULT=$(/usr/sbin/curl -k --silent " https://username:[email protected]/nic/update?hostname=home
padding:0in">=$IP")
logger "Results: $RESULT"
if [[ ${RESULT:0:4} == 'good' ]]
then
/sbin/ddns_custom_updated 1
else
/sbin/ddns_custom_updated 0
fi
Here is a link to the API for this specific DNS Provider. I'm not sure if there is something wrong with the script or if I've got something wrong with the credentials. The Username & Password are correct, I can affirm that.
https://www.safedns.com/nicupdate
This is the log I get from the System
Mar 29 00:26:41 rc_service: watchdog 442:notify_rc start_ddns
Mar 29 00:26:41 custom script: Running /jffs/scripts/ddns-start (args: 192.168.0.114)
Mar 29 00:27:11 watchdog: start ddns.
It just repeats itself over & over.
Thanks in advance for any potential help.
