Voxel Custom firmware build for Orbi RBK50/RBK53 (RBR50, RBS50) v. 9.2.5.2.30SF-HW
Voxel
Part of the Furniture
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-v-2-5-0-42sf-hw.60308/
https://www.snbforums.com/threads/c...50-rbk53-rbr50-rbs50-v-9-2-5-2-28sf-hw.84485/
https://www.snbforums.com/threads/c...50-rbk53-rbr50-rbs50-v-9-2-5-2-29sf-hw.85461/
New version of my custom firmware build: 9.2.5.2.30SF-HW.
Changes (vs 9.2.5.2.29SF-HW):
1. Toolchain: Go is upgraded 1.20.5->1.21.0.
2. OpenSSL v. 1.1.1 package is upgraded 1.1.1u->1.1.1v (fixing CVE-2023-3817, CVE-2023-3446).
(score 5.3, Medium)​
3. DNSCrypt Proxy v.2 is upgraded 2.1.4->2.1.5.
4. curl package is upgraded 8.1.2->8.2.1.
5. ethtool package is upgraded 6.3->6.4.
6. bind package is upgraded 9.18.15->9.18.18.
7. iperf3 package is upgraded 3.13->3.14.
8. util-linux package is upgraded 2.38.1->2.39.2.
9. tar package is upgraded 1.34->1.35.
10. less package is upgraded 633->643.
11. zlib package is upgraded 1.2.13->1.3.
12. libnl-tiny package is upgraded 2023-04-02->2023-07-27.
13. nghttp2 package is upgraded 1.54.0->1.55.1.
14. libjson-c package is upgraded 0.16->0.17.
15. lighttpd: add 'mod_h2.so' module to fix WebGUI access by HTTPS (@Ender).
16. Boost of kernel ('-O3', '-ftree-vectorize', '-fvect-cost-model=dynamic' compilation options for the whole kernel).
17. Host tools: upgrade UPX to 4.1.0.
18. Host tools: upgrade xz to 5.4.4.
19. Host tools: upgrade zlib to 1.3.
20. Host tools: upgrade gmp to 6.3.0.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Hello everyone!!
First thank you for this work to continue improving our Orbis.
I’m having trouble with the first step. When I downgrade the RBS50 to version 2.5.2.4 I see for a few minutes that it has been made but soon it is updated to the last version (2.7.4.24).
Did you know any way to downgrade and avoid the automatic update?
Thank you very much in advance
Hello everyone!!
Downgrade without having your modem plugged into the router. Then upgrade to voxel without having your modem plugged into the router. Then plug in everything once orbis are all on voxel.
@Voxel great work on continuing support for this model. Do you have firmware for the Orbi Pro SRK60? Netgear stopped releasing firmware updates last year? If not, can I use the RBK50 firmware you developed?
