Voxel Custom firmware build for R7800 v. 1.0.2.91SF
Voxel
Part of the Furniture
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-89sf.75539/
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-90sf.76155/
New version of my custom firmware build: 1.0.2.91SF.
Changes (vs 1.0.2.90SF):
1. Toolchain: Go is upgraded 1.17.5->1.17.6.
2. OpenSSL v. 1.1.1 package is upgraded 1.1.1l->1.1.1m.
3. OpenVPN is upgraded 2.5.4->2.5.5.
4. fcgi: fix QoS Internet Download/Upload display issue.
5. unbound package (used in stubby) is upgraded 1.13.2->1.14.0.
6. getdns package (used in stubby) is upgraded 1.5.2->1.7.0.
7. Add 'check' package ('getdns' dependency).
8. stubby package is upgraded 0.3.0->0.4.0.
9. curl package is upgraded 7.80.0->7.81.0.
10. libnl-tiny package is upgraded 2020-08-05->2021-11-21.
11. libexif package is upgraded 0.6.22->0.6.24.
12. e2fsprogs package is upgraded 1.46.4->1.46.5.
13. haveged package is upgraded 1.9.15->1.9.17.
14. expat package is upgraded 2.4.1->2.4.2.
15. dbus package is upgraded 1.13.18->1.13.20.
16. nano package is upgraded 5.9->6.0.
17. hd-idle package is upgraded 1.04->1.05.
18. redis package: optimize for a size.
19. dnscrypt-proxy-2: add UPX packing.
20. Host tools: upgrade e2fsprogs to 1.46.5.
21. Host tools: upgrade scons to 3.1.2.
22. Host tools: upgrade mkimage/u-boot to 2021.10.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
IAMP373R
Experiencing system crash and freeze up entirely while streaming IPTV on google TV with 90SF. IDK how it happens, and can't be reproduce. It seems to happen randomly.
Hopefully it will not happen again on 91SF. Beside that, it is very stable, thanks for the continuous improvement on the firmware.
All engines go! Thanks
For the TCP Congestion Control stuff again, i finally tried all the algo and found that cubic works best to me.
Thanks for inspiring me to try out other algo.
microchip
I did the same and found illinois to work best. Very snappy and can sustain the full bandwidth with minor drops during congestion but recovers quickly :)
Voxel
Your current environment is changed ;)? Just interesting for my next improvements.
I've had issues with illinois. If I set it on the router and all my Linux PCs, it would often just abort a movie I'm watching. As soon as I change to another CC, the problem goes away.
Voxel.
microchip
Voxel.
The issue was the kernel I was using on the NAS. It was running 5.14 which, after some investigation, had TCP and NFS bugs. I'm now on 5.14.21 and the problem does not occure
IAMP373R
Streamed IPTV for entire night on google TV, no freezing, no rebooting, no hanging. I think this is the version solve the problem.
BTW the stream(in 1080P quality) is pretty smooth, even go through bufferbloat test like nothing.
Voxel
did the fix for the QoS settings and Bandwidth monitor get implemented on this one?
Yes. It should be fixed.
Voxel.
