Custom firmware build for R9000/R8900 v. 1.0.4.34HF
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-4-32hf.57647/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-4-33hf.58296/
New version of my custom firmware build: 1.0.4.34HF.
Changes (vs 1.0.4.33HF):
1. proftpd package is upgraded from specific version with NG changes to 1.3.6 + CVE-2019-12815 security patch.
(Plus some changes in its behavior. Issue alarmed by kamoj)​
2. DNSCrypt Proxy v.2 is upgraded 2.0.25->2.0.27 (Firefox workaround).
3. OpenSSL v. 1.0.2 package is upgraded 1.0.2s->1.0.2t.
4. OpenSSL v. 1.0.2 package: patch to strip cflags from resulting binary is added.
5. OpenSSL v. 1.1.1 package is upgraded 1.1.1c->1.1.1d.
6. haveged package is upgraded 1.9.4->1.9.6.
7. uci package is upgraded 2019-05-17->2019-09-01.
8. unbound package (used in stubby) is upgraded 1.9.2->1.9.3.
9. libgcrypt package is upgraded 1.8.4->1.8.5.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Continuation of:
The link is:
Voxel.
Hi, sorry this is my first time using this firmware. Is QoS working as intended? I get "Start QoS failed. Please try again." I've tried enabling it on my R9000 with 4 different browsers with no success. I also did a factory reset as well.
QoS should work. My R9000 1.0.4.34HF:
Try to check with 1.0.4.32HF: QoS DB was updated since 1.0.4.33HF. So 1.0.4.32HF is with previous version of QoS.
Voxel.
