Custom firmware build for R9000/R8900 v. 1.0.4.39.1HF
Voxel
Part of the Furniture
Stay at home please, torment your router, save you family. COVID-19 it is seriously.
Now: You have a lot what to do. This is important release. Mainly because of using new Toolchain including significant changes such as latest GCC compiler v 9.3.0 released Mar 12, 2020 instead of old 4.8.5 (2015).
https://gcc.gnu.org/gcc-9/
Goal is obvious: additional performance boost because of modern compiler optimization.
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-38-1hf.62549/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-38-3hf.62650/
New version of my custom firmware build: 1.0.4.39.1HF.
Changes (vs 1.0.4.38.3HF):
1. Toolchain: GCC is upgraded 4.8.5->9.3.0.
2. Toolchain: binutils version is upgraded 2.32->2.34.
3. Toolchain: Go is upgraded 1.13.8->1.14.1.
4. NG/DNI bug in radvd is fixed (reported by microchip)
5. nano package is added (editor).
6. NG/DNI bug in UPG_upgrade.htm is fixed (by Kamoj).
7. transmission package is changed to use OpenSSL v. 1.0.2 (attept to fix https issue).
8. wireguard package is upgraded 0.0.20200215->0.0.20200318.
9. wireguard-tools package is upgraded 1.0.20200206->1.0.20200319.
10. libgcrypt sqlite3 wget packages: optimize for a size.
11. OpenSSL v. 1.1.1 package is upgraded 1.1.1d->1.1.1e.
12. DNSCrypt Proxy v.2 is upgraded 2.0.39->2.0.42.
13. bc package is upgraded 1.06->1.06.95.
14. libreadline package is upgraded 5.2->6.3.
15. libdevmapper package is upgraded 2.02.91->2.02.119.
16. e2fsprogs package is upgraded 1.45.5->1.45.6.
17. Changes in the Linux kernel and in many packages to provide compilation by GCC 9.3.0.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
@Voxel with this release, I want to buy a compatible NG router just to torment it! :)
Great updates and options for the NG community from you. Keep yourself and your family safe too! :)
Upgraded to this version, the only thing I became aware after reinstalling Kamoj's addon was the change to YeAH from Westwood for Congestion control.
Which is the correct setting? If any.
That sort of thing goes a bit outside my realm of knowledge, google searches give various opinions and something called TCP BBR, which isn't in this FW.
Sorry, I forgot to add into release notes. YeAH was set as default in 39.1HF...
You may switch to Westwood+.
Voxel.
Hello Voxel,
Thank you for the good work you are doing on R9000 and keeping it current with NG bugs out. Regards.
Roger12
I lost power to my R9000 and found it lost all settings afterward on this version - can anyone confirm/deny the same? It goes right back into factory setup every time for me.
Hello,
Does any one know how to Disable WPS on R9000? I can't find a setting to completely disable WPS on R9000. I am running Voxel. Thanks.
Roger12
Hello,
Roger12
Advanced > Advanced Setup > Wireless Settings > WPS Settings
disable router's PIN
firmware del router V1.0.4.39.1HF
Kamoj Add-on V5.1b9-1
R9000
OS log--->I only paste a piece of it, what can it be?
20814:[wifi1] FWLOG: [21336576] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20815:[wifi1] FWLOG: [21337600] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
20910:[wifi0] FWLOG: [21435650] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20911:[wifi0] FWLOG: [21436674] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
20915:[wifi0] FWLOG: [21440771] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20916:[wifi0] FWLOG: [21441795] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
20930:[wifi0] FWLOG: [21456131] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20931:[wifi0] FWLOG: [21457155] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
20965:[wifi1] FWLOG: [21491205] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20967:[wifi1] FWLOG: [21493253] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
20970:[wifi1] FWLOG: [21496325] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20972:[wifi1] FWLOG: [21498373] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
20973:[wifi1] FWLOG: [21499398] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20974:[wifi1] FWLOG: [21500421] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
20976:[wifi1] FWLOG: [21502469] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20977:[wifi1] FWLOG: [21503493] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
20978:[wifi1] FWLOG: [21504517] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20979:[wifi1] FWLOG: [21505541] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
20980:[wifi1] FWLOG: [21506565] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
20981:[wifi1] FWLOG: [21507590] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
20983:[wifi1] FWLOG: [21509638] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
20986:[wifi1] FWLOG: [21512710] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
20988:[wifi1] FWLOG: [21514758] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
20990:[wifi1] FWLOG: [21516806] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
20991:[wifi1] FWLOG: [21517830] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
20992:[wifi1] FWLOG: [21518854] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
20994:[wifi1] FWLOG: [21520902] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
20995:[wifi1] FWLOG: [21521926] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21001:[wifi1] FWLOG: [21528070] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21002:[wifi1] FWLOG: [21529094] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21003:[wifi1] FWLOG: [21530118] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
21004:[wifi1] FWLOG: [21531142] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21005:[wifi1] FWLOG: [21532166] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21006:[wifi1] FWLOG: [21533190] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21007:[wifi1] FWLOG: [21534214] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
21009:[wifi1] FWLOG: [21536263] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21010:[wifi1] FWLOG: [21537286] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21013:[wifi1] FWLOG: [21540359] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21016:[wifi1] FWLOG: [21543431] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21017:[wifi1] FWLOG: [21544455] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21018:[wifi1] FWLOG: [21545479] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
21019:[wifi1] FWLOG: [21546503] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21021:[wifi1] FWLOG: [21548551] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21022:[wifi1] FWLOG: [21549575] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21025:[wifi1] FWLOG: [21552647] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
21026:[wifi1] FWLOG: [21553671] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
21027:[wifi1] FWLOG: [21554695] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
21029:[wifi1] FWLOG: [21556743] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
21030:[wifi1] FWLOG: [21557767] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
21031:[wifi1] FWLOG: [21558791] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
21033:[wifi0] FWLOG: [21561606] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
21033:[wifi1] FWLOG: [21560839] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
21034:[wifi0] FWLOG: [21562630] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
21036:[wifi1] FWLOG: [21563911] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
21037:[wifi1] FWLOG: [21564936] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
21038:[wifi1] FWLOG: [21565959] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 )
21050:[wifi1] FWLOG: [21578248] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
21052:[wifi1] FWLOG: [21580296] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
21053:[wifi1] FWLOG: [21581320] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
21054:[wifi1] FWLOG: [21582344] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21055:[wifi1] FWLOG: [21583368] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21059:[wifi1] FWLOG: [21587464] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21061:[wifi1] FWLOG: [21589512] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21062:[wifi1] FWLOG: [21590536] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21063:[wifi1] FWLOG: [21591560] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21065:[wifi1] FWLOG: [21593608] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21067:[admin login] from source 10.0.0.2,
21067:[wifi1] FWLOG: [21595656] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21068:[wifi1] FWLOG: [21596680] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21069:[wifi1] FWLOG: [21597705] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21072:[wifi1] FWLOG: [21600776] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21073:[wifi1] FWLOG: [21601800] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21074:[wifi1] FWLOG: [21602824] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21075:[wifi1] FWLOG: [21603848] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21076:[wifi1] FWLOG: [21604872] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21078:[wifi1] FWLOG: [21606921] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21079:[wifi1] FWLOG: [21607945] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21080:[wifi1] FWLOG: [21608969] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21082:[wifi1] FWLOG: [21611017] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21086:[wifi1] FWLOG: [21615113] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21088:[wifi1] FWLOG: [21617161] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21089:[wifi1] FWLOG: [21618185] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21090:[wifi1] FWLOG: [21619209] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21093:[wifi1] FWLOG: [21622281] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21094:[wifi1] FWLOG: [21623305] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21096:[DoS Attack: TCP/UDP Chargen] from source: 35.211.182.206, port 40862,
21097:[wifi1] FWLOG: [21626377] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21098:[wifi1] FWLOG: [21627401] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
21100:[wifi1] FWLOG: [21629449] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21101:[wifi1] FWLOG: [21630473] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21102:[wifi1] FWLOG: [21631497] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21103:[wifi1] FWLOG: [21632522] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21104:[wifi1] FWLOG: [21633545] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21105:[wifi1] FWLOG: [21634569] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21107:[wifi1] FWLOG: [21636617] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
21108:[wifi1] FWLOG: [21637641] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x6, 0x0 )
21109:[wifi1] FWLOG: [21638666] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x5, 0x0 )
See my reply from last time you asked the same question:
https://www.snbforums.com/threads/kamoj-add-on-5-1-beta-testing-poll.62315/page-2#post-562673
https://www.snbforums.com/threads/kamoj-add-on-5-1-beta-testing-poll.62315/page-2#post-562700
If my previous answer was no good, please try google it and report back here when you know what it can be.:)
Or if we are lucky someone in this thread know what it can be!:cool:
R9000
tests carried out, if I turn off the wifi all the errors disappear, as when the wifi is turned on they return
Hi!
Running entware from 'tmp/plexmediaserver'
lrwxrwxrwx 1 root root 4 Apr 12 10:42 /opt/var -> /tmp
lrwxrwxrwx 1 root root 4 Apr 12 11:17 /opt/tmp -> /tmp
lrwxrwxrwx 1 root root 34 Apr 12 11:30 /opt/share -> /tmp/plexmediaserver/entware/share
lrwxrwxrwx 1 root root 32 Apr 12 11:31 /opt/etc -> /tmp/plexmediaserver/entware/etc
lrwxrwxrwx 1 root root 33 Apr 12 11:31 /opt/home -> /tmp/plexmediaserver/entware/home
lrwxrwxrwx 1 root root 33 Apr 12 11:31 /opt/root -> /tmp/plexmediaserver/entware/root
lrwxrwxrwx 1 root root 32 Apr 12 11:32 /opt/lib -> /tmp/plexmediaserver/entware/lib
lrwxrwxrwx 1 root root 32 Apr 12 11:32 /opt/bin -> /tmp/plexmediaserver/entware/bin
lrwxrwxrwx 1 root root 33 Apr 12 11:32 /opt/sbin -> /tmp/plexmediaserver/entware/sbin
lrwxrwxrwx 1 root root 32 Apr 12 11:32 /opt/usr -> /tmp/plexmediaserver/entware/usr
df -m
ubi1: plexmediaserver 257 46 207 18% /tmp/plexmediaserver
Running following services:
Thu Jan 1 00:00:11 UTC 1970 Entware services are started from /tmp/plexmediaserver!
Setting up swapspace version 1, size = 2147479553 bytes
Sun Apr 12 11:29:17 UTC 2020 Enabled swap #4
Starting rsync... done.
Starting netdata... done.
Starting unbound... done.
Starting minidlna... done.
Starting emailrelay... done.
Content of '/tmp/plexmediaserver' survived flashing official Netgear(1.0.5.14) & Voxel firmware!
Stay home & safe!
