Voxel
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-44hf.66185/
https://www.snbforums.com/threads/c...0-4-45hf-v-1-0-4-45-1hf-v-1-0-4-45-2hf.67112/
New version of my custom firmware build: 1.0.4.46HF.
Changes (vs 1.0.4.45.2HF):
1. Toolchain: Go is upgraded 1.15.3->1.15.6.
2. Toolchain: gdb is upgraded to 10.1.
3. Toolchain: make an order in binutils patches.
4. OpenSSL v. 1.1.1 package is upgraded 1.1.1h->1.1.1i (fixing CVE-2020-1971).
5. curl package is upgraded 7.72.0->7.74.0 (fixing CVE-2020-8284, CVE-2020-8285, CVE-2020-8286).
6. OpenVPN is upgraded 2.4.9->2.5.0.
7. lz4 package is upgraded 1.9.2->1.9.3.
8. wireguard package is upgraded 1.0.20200908->20201112.
9. util-linux package is upgraded 2.36->2.36.1.
10. iptables package is upgraded 1.8.5->1.8.6.
11. ipset package is upgraded 7.6+ [2020-03-09]->7.9.
12. ethtool package is upgraded 5.8->5.9.
13. iw package is upgraded 5.8->5.9.
14. libnl-tiny package is upgraded 2019-10-29->2020-08-05.
15. libgcrypt package is upgraded 1.8.6->1.8.7.
16. libgpg-error package is upgraded 1.37->1.39.
17. sysstat package is upgraded 12.4.0->12.4.1.
18. minidlna package is upgraded 1.2.1-2019-12-09->1.3.0.
19. ffmpeg package is upgraded 3.4.8->4.3.1.
20. libexif package is upgraded 0.6.21->0.6.22.
21. ubus package is upgraded 2020-10-25->2020-12-04.
22. proftpd package is upgraded 1.3.6e->1.3.7a.
23. nano package is upgraded 5.3->5.4.
24. unbound package (used in stubby) is upgraded 1.11.0->1.13.0.
25. transmission package is upgraded 2.94->3.00.
26. Change WebGUI info for OpenVPN 2.4.x->2.5.x.
27. libcryptoxx final size is reduced to save a space (LTO optimization).
28. Host tools: upgrade bison to 3.7.4.
29. Host tools: upgrade gmp to 6.2.1.
30. Host tools: upgrade mpc to 1.2.1.
31. OpenVPN server: add 'CHACHA20-POLY1305' cipher to 'ncp-ciphers' option and change the cipher of downloaded config for Windows clients to 'CHACHA20-POLY1305'.
(Important: it is highly recommended to use 'CHACHA20-POLY1305' if your client is based on v. 2.5.x, much faster,
change your non-Windows client config if possible).
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
The link is:
Voxel.
