Voxel Custom firmware build for R9000/R8900 v. 1.0.4.52HF
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-50hf.71991/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-51hf.72644/
New version of my custom firmware build: 1.0.4.52HF.
Changes (vs 1.0.4.51HF):
1. Toolchain: Go is upgraded 1.16.4->1.16.5.
2. Fix of PLEX startup script issue (NG/DNI bug).
3. curl package is upgraded 7.76.1->7.77.0 (fixing CVE-2021-22897, CVE-2021-22898, CVE-2021-22901).
4. expat package is upgraded 2.2.10->2.4.1 (fixing CVE-2013-0340).
5. wireguard package is upgraded 1.0.20210424->1.0.20210606.
6. OpenVPN is upgraded 2.5.2->2.5.3.
7. proftpd package is upgraded 1.3.7a->1.3.7b.
8. util-linux package is upgraded 2.36.2->2.37.
9. libubox package is upgraded 2021-03-02->2021-05-16.
10. ubus package is upgraded 2021-02-15->2021-06-03.
11. libxml2 package is upgraded 2.9.10->2.9.12.
12. iperf3 package is upgraded 3.9->3.10.1.
13. nano package is upgraded 5.7->5.8.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Hello Voxel,
I am currently running V1.0.4.47HF, planning to upgrade to the latest ASAP. But I have a small problem...
I disabled uPNP (Turn UpnP On checkbox is not checked), but underneath I have a full list of ports which seems to be active (Active = YES).
Point in case: I need to forward a certain port to an IP, but apparently that port is already in use by uPnP for another IP.
So how to fully disable uPNP, or is this by design?
Will a reboot free up the ports?
Hello Voxel,
Wait for a new release of my build. Coming soon.
Voxel.
