Voxel Custom firmware build for R9000/R8900 v. 1.0.4.58HF
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-56hf.76160/
https://www.snbforums.com/threads/c...9000-r8900-v-1-0-4-57hf-v-1-0-4-57-1hf.76826/
New version of my custom firmware build: 1.0.4.58HF.
Changes (vs 1.0.4.57.1HF):
1. Toolchain: binutils version is upgraded 2.37->2.38.
2. Toolchain: Go is upgraded 1.17.6->1.17.7.
3. util-linux package is upgraded 2.37.2->2.37.4 (fixing CVE-2021-3995, CVE-2021-3996, CVE-2022-0563).
4. expat package is upgraded 2.4.3->2.4.6 (fixing CVE-2022-23852, CVE-2022-23990).
5. aws-iot: add possibility to disable Amazon Alexa (@NetBytes, @spocko):
nvram set noaws=1​
nvram commit​
reboot​
6. iptables: add patch to disable exit if no library for match (@HELLO_wORLD).
7. dnscrypt-proxy-2: change startup priority to 98 (@microchip).
8. exfat-nofuse package is upgraded 2017-06-20->2018-04-17.
9. unbound package (used in stubby) is upgraded 1.14.0->1.15.0.
10. libusb package is upgraded 1.0.24->1.0.25.
11. ethtool package is upgraded 5.15->5.16.
12. iperf3 package is upgraded 3.10.1->3.11.
13. libxml2 package is upgraded 2.9.12->2.9.13.
14. nano package is upgraded 6.0->6.2.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Hi Voxel, sorry to hijack your thread, but is there a custom firmware for Netgear RAX80 with OpenVpn support? Does your firmware enable it? Just like on Asus where you can drop OpenVpn config file on the router and use OpenVpn ?
Sorry but 'no'. I do release my custom firmware for Qualcomm chipset routers. RAX80 is Broadcom. No any plans to support Broadcom because of 'too enclosed' GPL sources (no space for my improvements)...
RAX120 - rather in my plans. But not RAX80...
Voxel.
Voxel focuses mostly on Qualcomm routers from NETGEAR. Broadcom ones are a whole different story. The same goes for the kamoj addon.
Just because I can do much more with Qualcomm routers. Not because of my private comparison of Broadcom vs Qualcomm.
Voxel.
